VSS can be found on pin 80 in the ECU harness. This is on the third harness (furthest right if the push-tabs for the harnesses are pointed up), 2nd row, third pin from the left. Alternatively I read somewhere it can be found on the OBDII wiring harness as a black with yellow or red stripe, but I've not personally verified this.
Reverse can be found under the rear seat on either side of the car in wiring bundles running the length of the car. Look to the edge near the doors for the wiring bundles. The reverse line is the brown wire in those bundles. Alternatively you can find this wire in the trunk going to the rear lights.
Posted Oct 18, 2006 ยท 18:41 UTC#1
