How to disable "Snap-to-road" feature?
By pdyebrasil · Apr 01, 2009in Hacks/Mods💬 4 posts👁️ 853 views
Posted Apr 01, 2009 · 02:39 UTC#1
Hey guys,
I've searched a few time and couldn't find how to disable the snap-to-road feature. I know it is possible, but could someone point me in the right direction?
Posted Apr 01, 2009 · 03:13 UTC#2
It isn't enabled in the OEM data.zip. My data.zip and IDT's for sure have the setting. I'm sure a few others do as well. The setting is under NaviSettings/Route where you can also select vehicle type. Check out the mods on my FTP
ftp://avic:[email protected]/
Read the readmes and look at the pix in each user's folder. Any of them are far better than the OEM version, so pick the one you like the best. :-)
I have put an all-in-one file on there in my folder(cmh928) aimed at newbies to get you started modding.
Posted Apr 01, 2009 · 12:58 UTC#3
You only need to mod if you want the option displayed when vehicle type = car. Otherwise, just set it to pedestrian and the AlignToRoad is displayed (and off by default). See comments in the "iGO sys.txt" thread: you need to mod both common/ui/setting.ui and sys.txt.
Posted Apr 01, 2009 · 17:12 UTC#4
Hey thanks guys. I'm going to see if I can get it working today :)
