My ML 320 has a lead going to the OEM headunit called "Backup lamps reverse NAV". Would this be the correct lead to connect to the the D2 Voilet/white (reverseg ear signal input): Also the OEM head unit has a lead called ESP/ETS/BAS control module, speed dependant volume, VSS Nav. Would this be the correct lead to connect to the D2 pink(Car Speed Input)?
Any help or suggestions would be greatly appreciated.
Posted Oct 18, 2006 · 19:47 UTC#1
