Duz purple backup cam wire have diode already?
By PeterUbers · Apr 01, 2009in General💬 7 posts👁️ 1,032 views
Posted Apr 01, 2009 · 16:29 UTC#1
i was told to diode isolate the purple wire for the backup camera from the OEM reverse wire --
is that little back cylinder on the purple wire (AVIC purple wire) a diode/fuse inline? Or do I have to add a diode. If so, what direction should the diode go? thanks
Posted Apr 01, 2009 · 16:34 UTC#2
There's no diode in the wire, there is a current limit resistor. Why is it that you think you need a diode?
Posted Apr 01, 2009 · 17:27 UTC#3
I've read multiple times that it's important to prevent feedback from the AVIC system back to the BCM by using a diode to isolate the circuit from the reverse wire circuit...
any truth to this?
Posted Apr 01, 2009 · 17:37 UTC#4
You shouldnt need a diode. But if you insist on installing one, youd want the arrow pointing towards your avic unit.
Posted Apr 02, 2009 · 15:54 UTC#5
i have had some cars show that the parking brake was on when it wasnt do to the wire being connected, a diod fixed the problem
and you only want the arrow or line pointing to the AVIC if you have a +pos reverse wire, the arrow or line needs to point towards the wire if you have a -neg reverse wire
Posted Apr 02, 2009 · 16:29 UTC#6
Excellent info guys, thank you.
Posted Apr 04, 2009 · 13:27 UTC#7
So i installed my F90bt w/ backup camera this weekend --
I ran the purple/white wire straight to the reverse light 12vdc wire and did not use a diode -- all is working fine!
Thanks guys
