OK, ready to give up on data.zip!?!?!!?!
By 08TitanSE · Apr 01, 2009in Hacks/Mods💬 16 posts👁️ 1,994 views
Posted Apr 01, 2009 · 18:14 UTC#1
I have scoured this forum, and I can't seem to find an answer. I have an 8gb Sandisk SD Card. I have no problems loading peoples different data.zip files, and no problem getting into testmode. In fact, I dont even have a problem finding the data.zip file once I get into testmode.
What I can't figure out is, how do I "load" the data.zip file onto my unit???? Is it supposed to load automatically due to it's file name? Am I supposed to do something else while inside testmode?
When I do click on the data.zipfile once inside testmode, a box pops up that says the file is not supported by the unit.
Please help!!!!!
Posted Apr 01, 2009 · 18:29 UTC#2
Go into testmode and then open up the windows explorer in wince and copy the data.zip from your SD card to your apl2\igo directory where the existing data.zip is. Make sure you backup first before you overwrite.
Posted Apr 01, 2009 · 18:34 UTC#3
Stupid question, how do I get to the apl2\igo directory?
Posted Apr 01, 2009 · 18:38 UTC#4
One more question. Isthe data.zip file supposed to show up as a "file" icon when looked at from testmode? Because it doesn't show up that way for me.
Posted Apr 01, 2009 · 18:40 UTC#5
See above? So you haven't found the original data.zip file on the flashdisk? The above assumes you have loaded other data.zip into the unit If I misunderstood that comment sorry.
When you get into test mode a box will open up loading files. you have to click in the upper right corner on the close button and close that box. then you got to bottom left start |programs|windows explorer. This will be like navigating windows explorer on your PC. You should have a bunch of folders one of them named flashdisk and one SD card. Go to flashdisk, then in there APL2\IGO and in there is the main IGO files and folder and the data.zip you need to replace with the one from your SD card. As I said, backup first before you copy anything
Posted Apr 01, 2009 · 18:44 UTC#6
Also you might want to read the hacks and mods section that explains how all of this works before you start trying to hack your unit. The questions your asking have been answered numerous times in these forums.
Posted Apr 01, 2009 · 19:37 UTC#7
Yes, I do apologize. I think my eyes must have gotted tired trying to find what I was looking for. Thanks for the help guys!!!
Posted Apr 01, 2009 · 19:55 UTC#8
Did you figure it out though?
Posted Apr 01, 2009 · 20:08 UTC#9
I feel so stupid right now. So I make a backup of the stock data.zip, and replace it with one "hacked" data.zip. I have sucessfully replaced the data.zip file, and restart the system. Now the Nav doesn't work.
Every time I push the MAP button, it goes right back to the spash screen for like 30 seconds. Won't run Nav at all. So I returned it back to the factory data.zip file, and it works fine. After going through 3 seperate hacked data.zip files, I gave up. Returned it back to the factory data.zipfile, and now it works fine.
I am obviously doing something wrong, but I cannot for the life of me figure it out. What am I missing here? I swear I have enough computer knowledge to get through this!!!
Posted Apr 01, 2009 · 20:25 UTC#10
not 100 percent sure, but also sys.txt, (font).txt and ezrider files. Whos pack are you using?>
Posted Apr 01, 2009 · 20:50 UTC#11
So far BorisM, and both of dpdurst's mods. No worky,I feel so damn stupid
Posted Apr 01, 2009 · 22:08 UTC#12
You need to copy all the files within the sys.zip file in the apl\igo folder and also copy the data.zip. That at least should get you working, however as I mentioned I am using the modified ezrider.exe and license file. I'm not sure what will happen if you don't use that I didn't test it just stock with my mods. Since I didn't test this with stock ezrider.exe it would be good that you at least copy in the newer one and the license file that goes with it.
Back out your changes and go back to stock. make sure the unit works.
Download this new ezrider.exe and license file and copy to correct locations make sure the unit boots up and map works. If it does great. Next is to copy in the new data.zip and files in sys.zip and test unit right there. If your still good we can go from there. If you don't have all the stock files let me know I'll zip them up as well for you.
http://igo8.gpssoftware.us/avic/newez4avic.zip
Posted Apr 02, 2009 · 21:31 UTC#13
So I think I have this straight. The sys files get unzipped, and placed in the igo folder? Or do they remain zipped?
Posted Apr 02, 2009 · 21:46 UTC#14
unzip the file and copy everything to igo folder, make sure you back up everything before doing so
Posted Apr 02, 2009 · 22:48 UTC#15
WOOOOOOOHHOOOOOO!!! Got everything working. Thanks to everyone for your help.
Posted Apr 03, 2009 · 20:44 UTC#16
Awesome..
