Battery died right after installing D3
By taylorwilsdon · Apr 02, 2009in Problems/Troubleshooting💬 2 posts👁️ 583 views
Posted Apr 02, 2009 · 05:08 UTC#1
I did a test run with the D3, only power installed and no remote turn on wire hooked up, so my amps were off, and I drove from my house to Sears (about a 15 minute drive) with the unit on the whole way. When I came back from Sears (10 minutes in the store), I put the key in and put it in the on position to prime the fuel pump. I knew immediately what happened... pump started to fill, normal ding, lights dim a little and DAMNIT! Battery is dead. Click, click. I unhook the harness to the D3 and still click, click. I pop the trunk (its a bmw, battery is in the trunk) and get ready to have to jump the battery, and about 30 second later the lights come back a little. It finally starts.
Why?! Why?! After all this cutting and mangling of my dash to make the double-din mounting kit fit, I learn its going to drain my battery?
The car is an E39 BMW 540i. The battery is fairly new (3 months perhaps) and is still good as far as I can tell.
I'm using a (I believe Metra brand) harness that hooks into my where my factory radio did. I only hooked up power, ground, illumination and one other one that I'm now forgetting.
Also, how do you turn the unit completely off while you're driving?
Posted Apr 18, 2009 · 15:04 UTC#2
Depending on what year and stock system you had in your car you may have a factory amp for your speakers, if so your metra adapter may not be turning the stock amp off and there for killing your battery. I would say go back and check your connections.
