I have a iphone and i'm able to view the video on F90 but not able to hear anything through my speakers? any help?
HELP - Ipod Video plays no sound???
Change AV1 Setting to iPod.
i did that, and made sure that the AV1 setting was at ipod. it still doesn't play any sound just the video keeps on playing.
I actually have the same problem. I have an I-Pod video and when I connect it I can see it come up on the screen and I can control it from the screen but I don't hear any sound. I signed on to post the exact same problem. I'd love to get this issue resolved so I can use my I-Pod.
and both of you guys used the ipod cable with usb AND composite video, right?
+1
yes you are correct i have the iphone/ipod plugged via the usb rca cables given, so how can we resolve this? could it be possible the ipod video sound might work if i get the Pioneer "CD-RM10" which is the AUX Mini-Plug to Composite A/V Cable? if not, what's my next option?
There is a setting on my ipod video that you have to change in order to get sound out from other than the headset jack. I don't currently own an f90bt so I can't say that this would fix it, but its worth a try. Again, the setting to change is on the ipod itself. Hope this works!
-Sean
Yep, in the video settings on teh Ipod you need to change it to "video out". I also had to mess around with some of the format settings on my Ipod to make it display properly on the screen, I think I used "widescreen". One other possibility could be that you hooked your audio connectors up to the wrong set of RCA connectors... Just a thought.
i tried all your suggestions and it hasnt been sucessful, unless there is some other setting on iphone/ipod that i'm missing or so. anybody know?
