Should I be hearing static?
By Niteowl · Apr 06, 2009in Problems/Troubleshooting💬 5 posts👁️ 1,367 views
Posted Apr 06, 2009 · 11:58 UTC#1
When I am playing an mp3 from the ipod, when I hit pause and the music stops, there is a low volume static coming from the speakers, is that normal? Did not wanna go back to the audio shop and complaing just to find out I am nitpicking.
Posted Apr 06, 2009 · 14:35 UTC#2
i didnt have this with my Alpine, but i do with my Pioneer
Posted Apr 07, 2009 · 15:50 UTC#3
I have the same problem please let me know if u figure this out it annoys the crap out of me
Posted Apr 07, 2009 · 15:58 UTC#4
do you have an EQ? if you do, turn the volume down a little bit.
do you have amps? turn down the gains a little bit and see if that does anything.
obviously if you have the volume turned all the way up, that sound's gonna be there, because of the volume you're trying to push. but if it's at low volume, then it's almost gotta be one of those two... unless it's something i don't know, which is possible haha
Posted Apr 07, 2009 · 16:06 UTC#5
the issue is with the pioneer, every one i install does the same thing. even with just using the internal amp and the volume very low, there is a ton more noise than just about every good radio i have used. i have used an Excelon, an Eclipse, and a couple of Alpine's and none of them has had this much noise, its not a problem, its just not the best quality. i would hope that the Premier is better.
