Installed a Z1 (aug06) in a 07 Chrysler Aspen using the Scoche Can Bus Interface. When driving the unit powers off then comes back on like nothing happen. Anybody else had this problem?
Does yours completle restart like you turned it off and turned it back on? If so, I have had the same problem in my G35. I thought I may have a loose connection or I forgot to connect the grounding wire or something. It only happens when I hit a bump.
No mine acts like the key in turned off and back on, and it only does it while driving it works fine while sitting still in park. I'm going to change my 12volt connection from the Can Bus interface to one from another source and see if it still happens. P.S. The bypass works fine.
If your cigarette lighter turns on and off with the key, try pulling the turn on for the z1 there. could be a problem with the canbus interface or a bad connection to it.
