msn direct not working even after resetting
By jimmy912 · Apr 06, 2009in Problems/Troubleshooting💬 9 posts👁️ 1,266 views
Posted Apr 06, 2009 · 18:03 UTC#1
My msn direct is keep connecting on status.....reset button doesnt work either...I havent activated msn before the I hacked, is this can be a problem????? :shock: Is there any other way to find my msn direct ID and activate on their website???
Posted Apr 06, 2009 · 19:06 UTC#2
Where is your location? You might have to me in an area that receives MSN
Posted Apr 06, 2009 · 20:40 UTC#3
I'M IN LOS ANGELES AREA.
Posted Apr 06, 2009 · 21:22 UTC#4
well Im pretty sure there is service out in L.A. I believe you might have to have the unit on for 30-45 min. to connect. And allso I dont believe that the would be a problem with your unit being connected with a bypass. I have min done with a hard wire bypass and msn direct is working
Posted Apr 17, 2009 · 00:51 UTC#5
Mine did the same after a reboot but I fixed it. Wait untill the system boots up then go to the msn status screen then reboot hold the eject button and the resetpin down at the same time that should fix the problem. :D
Posted Apr 20, 2009 · 23:11 UTC#6
I live in Los Angeles too and theres plenty of service out here.
Posted May 07, 2009 · 08:21 UTC#7
make sure you get good fm reception. msn direct uses a data version of fm frequency. my msn direct didnt work till i updated to 2.0 also
Posted Jun 03, 2009 · 04:27 UTC#8
Had similar experience even after resetting. Called MSN Direct support and they advised that the unit had to be on when they sent the signal to initiate the account. I had them do it while I was in the truck and waited for 20 minutes and everything worked just fine. The support person remarked that the 20 minute wait is something Pioneer does not really let you know.
Hope this helps.
Posted Jun 04, 2009 · 13:17 UTC#9
I still have this problem only mine says Firmware update failed please reinstall a proper firmware...
It sucks cause i know that to fix it i will have to send my unit back but i don't use the feature so i think i will ignore it
