anyone with F90bt and bose system step inside!
By Eddywill · Apr 06, 2009in Problems/Troubleshooting💬 5 posts👁️ 778 views
Posted Apr 06, 2009 · 23:01 UTC#1
I am fighting engine whine with this set up I am using a GMOS-4 and Pac swis its not bad but bad enough. Do any of you have a similar setup with no noise? I am on the verge of pulling it all out and double checking everything....
Posted Apr 07, 2009 · 05:30 UTC#2
i had/have alternator whine with my stock bose setup.. i moved my ground and it is better, only noticeable at low volumes now..
Posted Apr 07, 2009 · 16:50 UTC#3
reground the system, i would run a groung wire from the bose amp to the headunit, and turn down the gain on the interface module. one of the installers at my shop has the same problem with his tahoe
Posted Apr 07, 2009 · 20:53 UTC#4
I, too, had this problem and just turned down the gain on the gmos-04 and it went away. I had to play with it to turn it up as much as possible without hearing the engine whine. It works great with the exception that now when I play my dvd sound through the input on the back of the unit the volume is very low. I have tried adjusting the vol for each source but it doesn't fix this one. Everything else, though, is fine.
Posted Apr 07, 2009 · 21:33 UTC#5
So far I guess there is no magic. I have the gain down but I have to turn the radio to 45 to "thump". I may pull the adjustment out of the GMOS and wire a remote adjustment near my eq...... just a thought
