Just installed my F700bt with the hardware bypass. Like everything about it except that it reboots as soon as it connects with my phone (a HTC Touch WM6 smartphone). Sometimes after the reboot it can connect to my phone and not reboot again, and I can make or receive calls. Sometimes it takes several reboot cycles before it stabilizes. If I turn bluetooth off, everything else works just fine.
I searched the forum and found a couple similar problems. I did the "delete devices and re-pair" trick, but it didn't work for me. I also tried installing the jetwaremobile software on my phone. Didn't fix it either.
Since when it connects and not reboots, all phone futures work. So I am thinking it may not be a software problem. Am I getting a unit with a defective bluetooth component? I know from previous experience that some defective components need some initial crashes to "warm up" to the work.
There is the only (but rather major issue) I have with the unit. I appreciate any help you may provide. Thanks!
