Beautiful ipod control and grafix but no sound
By chemjab · Apr 07, 2009in Problems/Troubleshooting💬 5 posts👁️ 1,035 views
Posted Apr 07, 2009 · 22:47 UTC#1
on my 900BT using my iphone connected through the usb you get all the displays (album art, artist, title etc) you can advance songs, search cat, random. It seams you can do everything available except listen to the music.
I have seen a few post on iphones, I didn't see any answers that directly address this problem.
If anyone can share some wisdom, it would be greatly appreciated.
chemjab
Posted Apr 07, 2009 · 23:27 UTC#2
i have an iphone im using and it works great as long as you dont put the iphone right in front of radio (gsm) buzzing
but make sure you have av1 set to ipod and should work for u
Richard
Posted Apr 07, 2009 · 23:37 UTC#3
Richard
I did set av1 to ipod, but only after it was connected. Maybe it will make a difference to have it set prior to connection? I will try it again and post results.
Thanks for the reply.
Posted Apr 07, 2009 · 23:51 UTC#4
There are a ton that answer exactly this problem!
It's usually that :
A: You didn't change AV1 over to ipod
B: You didn't use an ipod cable with RCA composite jacks
C: You used an ipod cable with composite jacks but didn't hook them up.
ipod/iphone control is via USB, audio and video come in via RCA.
Posted Apr 08, 2009 · 00:00 UTC#5
It's usually that :
Brilliant!
OK that last line is exactly what I needed to know. Thanks. I am sure the shop didn't hook it up with RCA. I will take it back and ask them.
Thanks for your help.
Richard,
So of course when I tried it again no luck, I''ll bet the installers didn't hook up the RCA to AV1.
Thanks to both of you.
cheers
