Software Hack WON'T INSTALL, WHY?
By nwembly · Apr 09, 2009in Hacks/Mods💬 8 posts👁️ 1,241 views
Posted Apr 09, 2009 · 20:19 UTC#1
I have a NEW AVIC-F700BT which already came with the NEW 2.o firmware. I want to do the software hack, which I fully understand (I hope), and have put it on my SD card. But when I put it into my unit and then power it on to have it boot off of the SD card, to install the moded version, it does nothing. However, It is NOT the SD card, as it can read from it if I put some music files on it, it will read, see, and play them.
What do I need to do inorder to make this "software hacked Version" install on my unit?, (and yes I have put the folders right at the root, and all of that...but I am open to any ideas as I have been trying for several weeks now)?
Posted Apr 09, 2009 · 21:59 UTC#2
Check the DATA.zip, ensure your zipping the folders correctly and not a folder within a folder. i.e DATA.zip/DATA/(all of the folders).
Your goal is to have DATA.zip/(all of the folders).
About as dumbed down as you'll get me from.
Mike
Posted Apr 09, 2009 · 22:46 UTC#3
If I'm reading this correctly the SD card does not boot so you can get into testmode. If that's the case you need to make sure these 2 folders with whatever is inside them are in the root.
MiTACAP
Testmode
As long as those 2 folders are in the root of the SD card it should boot no problem from the SD. Once it does and your in Wince you can open up explorer and copy whatever files your trying to copy or run testmode with the new leetlauncher
Posted Apr 11, 2009 · 01:17 UTC#4
I have F500BT with firmware 2.0 and I can't get into test mode either. Two folders are on root and I've tried reformatting my SD card also. What's wrong? When I turn on the unit nothing happends just normal map comes up. Please help.
Posted Apr 11, 2009 · 06:13 UTC#5
I got in :D I needed to press reset button on the back of the unit to get into testmode.
Posted Apr 23, 2009 · 22:41 UTC#6
2.0 software
f700bt
extracted GTIMATT09 Data.zip files to SD Card along with Transportm.ttf
but its not loading the files i leave the card in before i start my car .
any help appreciated
Posted Apr 23, 2009 · 22:48 UTC#7
2.0 software
f700bt
once again, you have to make sure you put the test mode files onto the card also so that you can get into the windows CE screens. The mods dont install themselves (unless you use mods like Cmh982 that are self installing). you must copy the files into your device into there correct location. BUT MAKE SURE YOU FULLY BACK-UP YOUR UNIT BEFORE YOU DO ANY MODS TO IT SO THAT IF SOMETHING F''S UP YOU CAN RESTORE IT BACK TO NORMAL IF YOU DIDN'T MESS IT UP TOO BAD. There are threads already in the forum about how to do this (hint, look at wiki and/or stickied threads to find out ALL this info).
Posted Apr 23, 2009 · 23:45 UTC#8
got it finally thanks for the help i highlighted the files copied and pasted in the proper folder,
