I've been considering adding a RCA line driver to increase the line output from my F700bt to my existing rear factory amp. Would appreciate input from others on this forum with experience using them.
My AVIC has been installed for over two months and sounds great, but I realize that I'm not getting the same efficiency from my rear amp/speakers that I did with my factory H/U. In addition, I have needed to adjust the F700bt fader control to bias the rear speakers way too much. From other posts on this forum, the use of RCA line drivers is mentioned as a possible solution.
I believe PAC makes a RCA line driver that could work (Turbo 1). Let me know what you think!
