i can only load dpdurst dazip any other the unit stuck on starup please wait,can some body help me to fix this
Thank you
Thank you
i can only load dpdurst dazip any other the unit stuck on starup please wait,can some body help me to fix thisThank you
so the first mod you did was dpdurst data.zip? do have updated maps, poi's, hacked ezrider?
IDT, he has this going in another thread as well, I can't figure out if mine is working or not, can't get that answer I'm working with him trying to figure out his exact issue.
No it doesn't have updated maps, poi's, hacked ezrider,it seems that it has something that interferes with others
datas
Are you renaming other downloads to data.zip? Or just leaving them as unziptoSD.zip, or similar?
No it doesn't have updated maps, poi's, hacked ezrider,it seems that it has something that interferes with othersdatas
download this and put everything in your igo folder, remember to backup your originals, then let me know what happens
i rename them to data do i need to rename to data.zip
i tried but the system stuck on starup and then reebot,I was looking at dpdurst data and i found that it has a folder
ui_igo8 others datazip don't have it .it could be that something of this folder remains in the system interfering with others
If you have removed my data.zip then that folder and anything inside it is not in the system. Have you removed all my other files from the sys.zip that you installed as well? and put back those originals. If I was you, I would put the system back at default and then copy whatever it is your trying to copy into the unit and see what happens.
when you say to put the original ones you.which one , igo folder or just sys.zip
You used my data.zip and the contents of the sys.zip correct? Replace those files with your originals and remove any extra file that you installed from my sys.zip from your system. That should put you at default unless you added other stuff from my page that you have not mentioned. Once you have a default unit, then install the new stuff from IDT and see if the unit works.
Normally when someone says put the unit back to default, that means all files that you added to the unit you remove and put back those original files. Any files that you added that are not original files you remove.
first off we don't have ui_igo8 in our data.zip, i don't know why dpdurst has it but for our system it's ui_pioneer, i compared dpdurst files with mine and found a couple of differences download this file and try it, http://ul.to/xoezyb
IDT ,,I put it back to default and it's working ,the only thing I had to remove borism schemes because it crash when
I use them, so for for the time being i going to use pioneer schemes
IDT,where this file goes asbis_PNA
IDT everything is working, my unit loocks beautiful, thanks for all your help
first off we don't have ui_igo8 in our data.zip, i don't know why dpdurst has it but for our system it's ui_pioneer, i compared dpdurst files with mine and found a couple of differences download this file and try it, http://ul.to/xoezybIDT everything is working, my unit loocks beautiful, thanks for all your help
the asbis file goes to license folder, glad it's working now
