F900BT continuing to reboot over and over
By SFNavi · Apr 14, 2009in Problems/Troubleshooting💬 22 posts👁️ 10,857 views
Posted Apr 14, 2009 · 19:24 UTC#1
I have recently updated the firmware to 2.0 and the unit seem to work fine for a couple minus the long delay on the BT to disconnect but thats another problem. About 5 days later I get in my truck and the unit turns on and i go to select a A/V source and it reboots and continues to reboot every time you start to mess with it. Its almost like its freezing up and then justs reboots itself. I can not get into any menu screens or any thing to see whats going on. Has anyone had this problem or know what i can do to fix the problem. Thanks
Posted Apr 15, 2009 · 02:05 UTC#2
There's two potential fixes, boot your unit into test mode and search for 4 files named gpspara0.bin, gpspara1.bin, gpspara2.bin and gpspara3.bin delete them and reboot. See if that fixes it. IF not, you'll probably need to reload it.
Posted Apr 15, 2009 · 11:43 UTC#3
Ok, now how do I boot the unit into test mood?
Posted Apr 15, 2009 · 17:27 UTC#4
you have to get the testmode and mitacap files onto a SD card and insert the SD card into the slot with the unit off. when you start it up, it will have a screen that says "copying files..." let it do its thing, then close that window and open up "my flash drive" and look for those files that you are supposed to delete. i just learned all this stuff the hard way two days ago. :D
Posted Apr 15, 2009 · 17:42 UTC#5
Look at the second post in this thread
viewtopic.php?p=127139#127139
Posted Apr 16, 2009 · 18:16 UTC#6
Thanks, I will be trying this tonight. I hope it works.
Posted Apr 16, 2009 · 21:23 UTC#7
Just finished up... Everything seems to be working good. I'm headed out for a 2 hour ride, hopefully there won't be any problems. Thanks again for everything.
Posted Apr 17, 2009 · 13:25 UTC#8
SFNavi, please detail what fixed your issue and what steps you took.
Posted Apr 17, 2009 · 16:16 UTC#9
Ok things seem to be working fine for now. Here is the list of what I did...
1) Go the link http://www.avic411.com/forum/viewtopic.php?p=127139#127139 go down to 2nd post and download the files for Test Mode. Put the 2 files "mitacap and testmode" on the root of your SD card.
2) Next insert your SD card with the test mode files on it and start your vehicle. Allow the unit to copy over the files and then the screen will turn green. Take your stylus and close it out in the upper right hand corner. You should now see the windows screen.
3) Open the Folder "My Flash Drive". There should be about 10-15 files in there. Look for the files named " gpspara0.bin, gpspara1.bin, gpspara2.bin and gpspara3.bin . These are the files you need to delete. I connected my USB drive and copied them over to there first just incase I had a problem. Thats up to you. They will be recreated once you turn your unit back on. These are the only 4 files that I deleted.
4) Once this done disconnect your USB drive and remove your SD card from the slot. Then take your stylus and push and hold "5 seconds" the reset button, this is the small little button near the eject button.
5) Give it a minute or 2 to boot up and then you need to go in and reset your EQ, presets, and GPS Home. This is the way that fixed my problem hopefully it will work for others.
Posted May 04, 2009 · 02:38 UTC#10
I created an account just to say thank you and that the above steps worked. I went out and bought an sd card and reader.i did the testmode and deleted those files stated to do so and now it works like a champ. this reboot nonsense is BS but hey shit happens. thanks a lot
Posted Oct 05, 2009 · 15:46 UTC#11
Hello everyone in this site
I tried to erase the 4 files posted above
but my avic wont start in test mode i did everything exacly as it says but wont detect any files
thanks in advance
Posted Oct 05, 2009 · 15:49 UTC#12
by SFNavi on Fri Apr 17, 2009 4:16 pm
1) Go the link viewtopic.php?p=127139#127139 go down to 2nd post and download the files for Test Mode. Put the 2 files "mitacap and testmode" on the root of your SD card.
5) Give it a minute or 2 to boot up and then you need to go in and reset your EQ, presets, and GPS Home. This is the way that fixed my problem hopefully it will work for others.SFNavi
Private message Top
my avic isnot detecting my sd with files in it I did it exactly as it says in that post, but no luck
any ideas thanks
Posted Oct 05, 2009 · 19:00 UTC#13
I can't get my F-900 to even go to test mode. Any suggestions?
Posted Oct 06, 2009 · 05:45 UTC#14
Help me!
I am in Hungary, I have a Pioneer AVIC F900 BT. type of navigation device.
Come 2:05 version. The maps I would like to replace it, but I do not know, because I always rebootol.
The maps are the same (8.0) device.
What can be done to change the maps to know?
Posted Nov 27, 2009 · 23:11 UTC#16
I have this same issue. In the past all I had to do was boot into test mode then delete the gpspara.bin files then it would be resolved, but now my unit won't go into test mode. It just keeps rebooting at the startup screen. Help please
Posted Dec 20, 2009 · 23:40 UTC#17
thanks for the help it saves my unit :D
Posted Dec 22, 2009 · 16:54 UTC#18
F900 will not boot into test mode appears not to even access the SD card...HELP
Posted Dec 29, 2009 · 03:39 UTC#19
Make sure the MapDBInfo.txt file in \MiTACAP\APL2\iGo\content states
Area: EW
and not anything different if your headunit is for the European market.
Posted Mar 14, 2010 · 16:54 UTC#20
I have tried this but the problem still exists. I have the F90BT with software bypass and brake grounded.
Posted Mar 16, 2010 · 10:47 UTC#21
Will this work for the 700? What's the stylus? This is what I'm getting: Start the truck, unit goes to the "Pioneer" screen, the for 5-7 seconds goes to the "main menu" screen with start up note over it. After 5-7 seconds, goes back to "Pioneer" screen for 20 seconds, and the cycle continues..... Is this what you all are talking about??
Posted Sep 09, 2017 · 07:35 UTC#22
does this work for a f930bt 2?
