iphone+BT+help
By ITR632 · Apr 16, 2009in General💬 7 posts👁️ 1,737 views
Posted Apr 16, 2009 · 19:25 UTC#1
Just got a 2G iphone. I can sync it up to the D3 and make calls, everything works and sounds great. However, when I leave the car and come back, I have to pair it up again... The pioneer is set to automatically connect, I didnt have this problem with my HTC dash. I really dont want to have to pair it everytime i want to use BT. Any help?
Posted Apr 20, 2009 · 19:12 UTC#2
Nothing? Really?
Posted Apr 21, 2009 · 01:46 UTC#3
Did you register it with the D3? Simply pairing it isn't good enough. Also check to make sure the power and ground are hooked up to the bluetooth module.
Posted May 15, 2009 · 14:03 UTC#4
What do you mean register? I had a T-mobile dash before and it worked fine, but i have to re-pair this damn thing every time i want to use the hands free..... Any help is much appreciated.
Posted May 19, 2009 · 05:15 UTC#5
PAIR your phone, and then follow directions below.
You can register a phone that is temporarily connected to this unit in order to take full
ad-vantage of the features available with Blue-tooth wireless technology. A total of five
phones can be registered: three user cellular phones and two guest phones.
When registered as a user phone, all the possible functions are available for use. When registered as
a guest phone, some functions are limited.
1 Touch PHONE REGISTER on the function
menu.
2 Touch and hold one of the registration
assignments to register the currenctly con-
nected phone.
Select from the following:
1 (user 1)—2 (user 2)—3 (user 3)—G (guest 1)
— G (guest 2)
If the registration is succeeded, the device
name of the connected phone is displayed in
the selected assignment.
If the assignment is empty, the device name is
not displayed. If the assignment is already taken,
the device name appears. To replace an assign-ment with a new phone, first delete the current
assignment. For more detailed instructions, see
Deleting a registered phone on this page.
# If the registration failed, device name of the
connected phone is not displayed in the selected
assignment. In this case, return to step 1 and try
again.
Posted May 31, 2009 · 06:56 UTC#6
I printed the instruction below and tried it by the line. Problem is when I get to the BT Tel, the Function tab is greyed out. So I cannot follow the registration procedure. Though when I paired the phone with the D3, it showed my Iphone name. You guys have any idea why my D3 is this way? :?:
Thanks for the help. I am eager to have my Iphone auto-connect to the unit.
Posted Jul 24, 2009 · 02:10 UTC#7
Just updating the thread...was able to program the unit per the instructions above. I was also able to use/hook up the BT Audio feature with my iPhone 3G. Thanks. :)
That handbrake lever had more functionality than I ever thought... :lol:
