I just installed my F900BT using a Scosche FD23b adapter in an 06 Explorer XLT (previous radio: OEM single CD, no sub).
I connected all eight speaker wires, 2 power leads (yell and red), black and ILL.
The only wire I have not connected yet is VSS. Pkg brake is grounded and mute relocated and grounded. I connected the HUs ground to the wiring harness black wire (not directly to ground). Antenna not connected yet, waiting on adapter.
Everything is working OK, except the "accessory delay feature". The unit shuts off immediately after shutting off the key (old one did not).
There was a small(er) connector on the OEM radio that was not reused. Is this canbus? And perhaps the reason why acc. delay no longer works?
