Good solution for adding A2DP?
By Paladin · Apr 18, 2009in General💬 2 posts👁️ 839 views
Posted Apr 18, 2009 · 22:27 UTC#1
I stumbled across this and was wondering if this would be a good solution for adding A2DP to the AVIC?
http://www.amazon.com/BlackBerry-ASY-16 ... B00170KUM0
Maybe install it permanently on an input? I am unsure what would be the easiest way to add it, RCA in the back or just a cable to the front jack?
Posted Apr 20, 2009 · 05:22 UTC#2
You'd have to give up the line in in the rear or wire in an RCA switch (I recommend an auto-sensing unit) or have that plug sticking out, mucking up the face, which, you may as well just use a standard stereo-to-stereo cable instead of going through wires.
Depending on whether it defaults to on or not, you'd have to mount it so you could turn it on.
You wouldn't be able to skip or pause or anything through the head unit either, so really you're going to have to have your audio device accessible to change the songs, and push something to get it to work. Really, I'd go with a simple stereo plug if you're going to have to turn the device on and still control everything through the audio device.
