i installed my n2 software in my n1 unit resantly and now movies dont work with the car moveing. anyone know how to fix this problem? maybe how to revert back to old software?
Posted Apr 19, 2009 · 18:22 UTC#1
I did the same thing as you. I hated it. You also cant look up address in the Nav if you are moving to fast.
I had to revert back to the old version.
I bought the direcitons on ebay and I am sure you can find them on here.
I believe that you can do the same bypass as the N2 and this will fix your problem. FYI you will have to remove your case to do the solder as the N1 didnt have that opening in the case as the N2 does.
