Ok here's the deal I just recv'd it and I only have to follow Note #8. Here's the Note.....................
Plug is located on AV Switch panel. The AV Switch panel is the radio control panel. Connect a 150 ohm resistor to vehicle's pin 13 wire. Connect a 47 ohm resistor to vehicle's pin 12 wire. Connect remaining ends of resistor to the INTERFACE's white wire. Connect vehicle's pin 14 wire to chassis ground.
The AV Switch panel is the radio control panel. > OK
Connect a 150 ohm resistor to vehicle's pin 13 wire. Which one is the 150?
Connect a 47 ohm resistor to vehicle's pin 12 wire. Which one is the 47?
Connect remaining ends of resistor to the INTERFACE's white wire. How do I do this? Sorry but Do I splice and solder each one to the white wire b4 I install?
Connect vehicle's pin 14 wire to chassis ground. Do i just connect the ground from the harness to this pin?
Any info would be helpfull thanks. Plan on doing this 1st thing in the AM? The last of my installs.
K
Posted Oct 20, 2006 · 23:11 UTC#1
