ripping cd-r onto hard drive
By guest · May 11, 2006in General💬 8 posts👁️ 1,900 views
Posted May 11, 2006 · 20:47 UTC#1
does anyone know if you can rip cd-r onto the hard drive. crutchfield says you cannot. Has anyone tried? Thanks
Posted May 12, 2006 · 13:46 UTC#2
I do not believe this is possible...
I have tried numerous different ways. I have evn tried burning mp3 dvd's, but the unit would not see them as valid discs.
Until they hack the HD, the only way to get songs on t eh hd is by "recording" them from an audio cd.
Posted May 12, 2006 · 14:33 UTC#3
so if you burn an original using dual cd drives then itll werk? it wont werk if u dl the album from the internet? just trying to get it straight before i buy one. sorry for the repetitive questions.
Posted May 12, 2006 · 15:57 UTC#4
You can rip a cd -r onto the z1. I have did it a couple times already. I used nero to burn one cd and the other one was just a cd someone let me hold. So it can be done.
Posted May 17, 2006 · 00:22 UTC#5
What about "copying" not "ripping" a cd-r to the hdd? What I mean is, if I load a data cd-r that is filled with a hundred or so mp3 files..will this copy to the hard drive or can the Z1 only "rip" audio discs to the hdd? If that is the case, can the user set bit rate?
Thanks.
Posted May 17, 2006 · 01:08 UTC#6
Thanks.
no bit rate is settable as far as I can tell and you cannot copy mp3 files directly to the drive. The ONLY option is to "rip" an original CD. With that said I have ripped cdr (copied originals) as well. The manual says you're not suppose to be able to do that, so I';m not sure how it determines if it's an "original" or not.
Posted May 17, 2006 · 02:01 UTC#7
Sure you can record CD-R's, that are AUDIO discs - not mp3 discs. I only listen to live CD's that I've recorded at concerts and mastered to CD-R.
Works just fine. What they're talking about is CD-R's with the copyprotect bit set (SCMS). Most computer based software ignores or resets the SCMS bit to 0. Standalone (consumer) CD Recorders that are used to copy CD's usually set the SCMS bit to 1 - prohibiting further copies to be made.
Rick
Posted Jun 09, 2006 · 05:09 UTC#8
hijacking a thread to tell rick he has a PM.
