Rear camera help
By wgm5286 · Oct 21, 2006in General💬 5 posts👁️ 1,079 views
Posted Oct 21, 2006 · 11:10 UTC#1
Hi, Just installrd my D1, everything works great! The bypass was a cinch, thanks for the info! But My rear camera is giving me problems. I purchased one off ebay from a recommended seller KAWAMALL with the reverse image and ir lighting for night. The pic is very unstable very wavy and sometimes rolls vertically. I spoke with the seller and he asked me what type of input i needed NTSC or PAL. Cant find any info on this anywhere, does it make a difference? Also any troubleshooting tips? Thanks for any help.
Posted Oct 21, 2006 · 12:24 UTC#2
Yes it does make a difference.
You need NTSC.
Posted Oct 21, 2006 · 12:45 UTC#3
thanks!
Posted Oct 21, 2006 · 19:20 UTC#4
OK, I may look retarded after this question, but I keep noticing people saying they bought their rear camera with the image reversed. Why exactly would you want the image reversed? Just so it matches the rear-view mirror? I would think that if the camera were mounted lower (like to line up your trailer hitch) you would want the image not reversed.
Posted Oct 25, 2006 · 18:08 UTC#5
uhh why would you want that.
you will get confuse if it is not reversed. Imagine looking at the mirror when you backup, then looking at the d1 without the reversing image. You're will get confuse :roll:
most camera comes with the option to reverse or not reverse. So you can choose whichever you want.
