Couple quick HU install question 06 F150
By Itchiban · Apr 23, 2009in Vehicle Specific Wiring💬 2 posts👁️ 1,117 views
Posted Apr 23, 2009 · 02:21 UTC#1
My Avic 700bt just arrived and I'm trying to iron out all the details for the install before this weekend.
The Scosche factory wiring harness that sonicelectronix sent me has two wires for dimmer. One says "dimmer" (orange/white) and one says "dimmer ground" (orange/black). The harness off of the Avic only has "illumination" (orange) which I gather is for the dimmer, but there is only one wire. Does the orange/white from the factory harness go to the orange wire on the HU and the orange/black get grounded? Or does that orange/black "dimmer ground" not get used at all? Is the "dimmer" and "Illumination" even the same thing?
Second question is: Should I hookup the reverse signal input if I dont have a backup camera?
Thanks in advance!
Posted Apr 24, 2009 · 13:10 UTC#2
illumination wire can be hooked up to the dimmer wire. The orange/black negative dimmer doesn't get used. Tape it up. Don't ground it. No need to hook up reverse if you're not going to use a backup camera.
