No Mute Wire
By Sidit · Apr 23, 2009in Hacks/Mods💬 6 posts👁️ 1,007 views
Posted Apr 23, 2009 · 04:05 UTC#1
The harness that came with my f700bt doesn't have the yellow/black mute wire...
What's it used for, why don't I have it, and Can I still do the bypass?
I'm installing it tomorrow afternoon and noticed that the mute wire wasn't there earlier when wiring up my harnesses...
Thanks in advance!
Posted Apr 23, 2009 · 04:09 UTC#2
Just ground the parking brake wire and do the software bypass. My mod and many others already have it applied.
if you don't do the software bybass, you will get a message at 10mph saying the p. brake wire is improperly connected.
Posted Apr 23, 2009 · 04:23 UTC#3
Thanks for the speedy reply, glad to know there's a good community for this thing! =]
Do i still need to hook up the parking brake wire to my brake... or just ground it?
Posted Apr 24, 2009 · 04:05 UTC#4
Just for anyone else wondering the same thing, I installed the 2.0 update, grounded my parking brake wire without hooking it to the actual brake wire... works like a charm.
Posted Apr 24, 2009 · 20:33 UTC#5
I just got my F90BT today and will be installing it tonight when I get home from work. Do I only need to ground the parking break wire and apply the software bypass mod?
-Brian
Posted Apr 25, 2009 · 19:18 UTC#6
-Brian
If i were you i would be the full hardwire bypass just to be on the safe side. It only takes a few more seconds to do if you are installing it yourself anyway.
