Please Help: F700 Flash Drive Backup
By eomsux · Apr 23, 2009in Hacks/Mods💬 8 posts👁️ 1,094 views
Posted Apr 23, 2009 · 22:56 UTC#1
Can anyone please give me access to a copy of your original F700 Flash drive Backup. I tried to use an updated mod, and now, I have access to the radio and its functions, but dont the loading screen continues to show, I have no navigation and the unit will reboot after 5min or so. So If you have an original copy of your F700BT Flash Drive I would really appreciate it.
Thank you.
Posted Apr 23, 2009 · 23:05 UTC#2
ok, first try to re-install the mod (or re-install the older version of the mod) this should fix this issue. most of the time all it is when your unit does that is a messed up/corrupt data.zip file, reinstalling the data.zip or reverting back to one that worked before will prolly fix that. (might want to try redownloading the mod as well incase your download got messed up).you more then likely DONT have to do a full restore (just trying to save you time in getting your unit back right)
Posted Apr 24, 2009 · 01:05 UTC#3
I have tried reverting back to my previous mod, but still have the same problem. I tried installing a mod from Illdietrying, that was a self extractor. This is the first time I have used a self extracting mod, most of the time Ive been doing it manually so that I can backup the files that Im replacing. Im not sure what files were replaced from the self extractor, so Ill have to try a few more things. If that doesnt work, then Im just going to need a full restore.
Posted Apr 24, 2009 · 01:20 UTC#4
i think someone posted in his thread about having the same issue and he found out what it was and fixed it and put up a new one to use, check his thread. viewtopic.php?f=34&t=22695&start=375
Posted Apr 24, 2009 · 14:25 UTC#5
I have tired using this updated mod, but still no change. I would rather just get a copy of a stock F700 Flash drive and start all over again, so I can avoid the headache of trying different things and still not getting any positive results.
Posted Apr 24, 2009 · 20:54 UTC#6
Thank you.
Check here viewtopic.php?t=21618
The same thing happened to me and this guy was a life saver and real nice to help me out. I hope he can help you too.
It worked like a charm...
Posted Apr 24, 2009 · 22:35 UTC#7
I could give you a copy of my original F700 flash drive, but where do I upload a copy for you?
Do you use a particular file sharing program?
Posted Apr 24, 2009 · 22:58 UTC#8
you could just upload it to this site, http://uploaded.to
