POIs Rubbish!
By andythilo · Apr 24, 2009in Problems/Troubleshooting💬 12 posts👁️ 1,263 views
Posted Apr 24, 2009 · 13:39 UTC#1
Seems the UK F900s have really poor POI database. For example, there were no BP garages showing in my area when I was sat outside one!.
Also I was sat in the carpark of a big local hotel and yep, not in the POI database. Is there anyway to add in poi packs to the F900?
Posted Apr 24, 2009 · 16:01 UTC#2
You can add POIs in either UPOI (native iGO) or KML format. AVIC (or Navgate, I guess, for UK) Feeds software even has some functions for it.
ALternatively, you could try ddownloading the latest UK POI files for iGO and using those with a hacked license...
Posted Apr 24, 2009 · 17:28 UTC#3
Bloody Navfeeds is rubbish too!!! It will only convert 300 at a time, how USEFUL NOT!!!!!!!!!!!!!!!
I'm using POiEdit to convert TomTom OV2 files and there is a KML option, i'll try that.
Posted Apr 24, 2009 · 19:00 UTC#4
That should work better.... If it can convert to UPOI format, this is even better yet...
Posted Apr 26, 2009 · 03:31 UTC#5
Once you have the poi file converted what folder do you put it in on the unit?
Posted Apr 26, 2009 · 22:50 UTC#6
\APL2\iGo\CONTENT\USERDATA\POI for KML files.
UPOIs would go either there or into \USER\UserData\iGo\save
Posted Apr 27, 2009 · 02:59 UTC#7
Thank you Boris for responding! I put a .KML file and a UPOIs file in \USER\UserData\iGo\save I would assume to test it I would do a search for the POI I put in there but when I do a search nothing comes up. I do not have the folder \APL2\iGo\CONTENT\USERDATA\POI should I create that folder?
Posted Apr 27, 2009 · 04:31 UTC#8
You're welcome!
I believe KML's would be recognized only from APL2 hierarchy -- iGO needs to process them and generate some internal files. I do have the userdata fiolder. If you don't, probably just create it...
Posted Apr 27, 2009 · 16:09 UTC#9
You're welcome!
That did it I added the USERDATA folder and it worked! Thanks! Any thoughts on how to get the icons to work now! :D
Posted Apr 27, 2009 · 16:29 UTC#10
Glad you got them working...
If you mean POI icons, if you go to settings, there's an option to assign icons to any POI catecory...
Posted Apr 27, 2009 · 22:32 UTC#11
Ok I found the settings and how to assign the category but the icons I placed in the USERDATA\POI folder did not come up. IS there a paticular format i need to use? (BMP or JPG) or is there another folder I need to stick them in?
Posted Apr 27, 2009 · 23:15 UTC#12
AVIC Feeds sorta kind does it for you. You oculd use a branding file with more icons, or I think if you drop a bitmap and an SPR file that matches it there, that should work too.
