ok I am having some issues, which may be nothing more than settings not being changed.. so here goes...
1. I am going to VIR (a raceway in Virginia) this weekend.. I want to put its address in as a destination or POI, but when I type it in (the address) it will not find the street. Would not find Alton, VA at first until I did the zipcode, and now when I go to type in the Street (Pine Tree Rd.) it will only allow me to type Piney Grove.. the rest of the letters are greyed out. Am I doing something wrong?
2. In the little colored booklet they sent out does it have all the instructions on how to add routes to your favorites, organizing POI's, etc.? I don't have it with me at work, but I just rememebred I had it and I am not sure how to do things like stop the route (just delete it?) I would have thought it woudl have come with a slightly more detailed booklet, like a camera has
3. Why when I am sitting in my driveway is it saying a different house number on my street? I have set my home location to my address, but if I am in my driveway it is saying 850 instead of 808 Perrymont... which is 200 ft away.
4. I have changed the daytime to Pionneer blue and the nighttime map mode to Pioneer Red.. however neither one seem different, they both look like a white map. When I turn my lights on nothing changes either... though when I toggle back to the map for a split second.. the map is black with the streets visible, which I assume is the nighttime mode. But I can't get it to that mode.. is something hooked up wrong?
5.I am going to hack it a bit ( as soon as I get a new SD card - keeps saying mine is full even though nothing is on it... its a 1GB so must be a big file.... just so I am clear here are the steps in doing the mods
- insert flash disk card with Testmode and MiTACAP installed
- go to windows environment and copy the "my flash disk" file over to the SD card
- make another back up copy on the HU itself in a new folder
- put SD card back in PC - and this is where all the code will be correct? Unzip Data.zip(is that right) and I can
access all the code?
- then is it just a matter of changing values, adding code, adding different files (ie sounds, mods, etc.)
- then do I zip it back or leave as is to put it back in the SD slot? Someone on here said do each mod 1 at a time.. that seems as though each file is separate and I can just put the SD card back in and drag each individual file I have modified over..
thanks for the help!!!
