Address's Suddenly Display With "/" and "?" Now...WTF??
By 69sixpackbee · Apr 24, 2009in Hacks/Mods💬 5 posts👁️ 706 views
Posted Apr 24, 2009 · 20:28 UTC#1
Now I am not getting the correct info displayed on the current street name and when I punch in a "go to" address to find. For instance, I typed in a city, and street name and then I type in a house number, in this case a four-digit number. I typed in "1535 N. San Antonio Ave" and when the displayed info comes up in the gray shadowed box it displays exactly like this:
"1535 26/?50" for the address and all of the rest of the info is correct just the address has the slash delimeter and a question mark along with the extra added digits. I have not updated any maps and have not done anything other that some mods to the Navigate_map files.
What is causing this and where can I go to fix it??
Thanx,
Bud
Posted Apr 24, 2009 · 20:49 UTC#2
You did a sys.txt hack from an IGO forum. Those are the average and max road speeds used to determine routing times.
Putting show_speed_limit=1 in the [debug] section
of your sys.txt file should allow you to investigate
without driving. Tap a street and an indicator like "35/?50"
will be prefixed to the street name in the street info box.
Posted Apr 24, 2009 · 21:24 UTC#3
Actually, I just changed the SYS.txt that you had supplied with your AIO with one I had with the larger default 8300 zoom and the original large 3D arrow. I'll swap them back and re-post my findings.
Thanx!
Bud
Posted Apr 24, 2009 · 21:30 UTC#4
I had a line in this sys.txt that I swapped out earlier with your AIO one:
"show_speed_limit=1"
That's probably the culprit.
Don' know whay I put it in there in the first place.....brain fart I guess.
I'll swap 'em and let ya know.
Thanx!
Posted Apr 24, 2009 · 23:13 UTC#5
Yep...that was it!
Thanx CMH !!
