2008 Subaru Impreza VSS location?
By boots · Apr 25, 2009in Vehicle Specific Wiring💬 4 posts👁️ 2,268 views
Posted Apr 25, 2009 · 05:06 UTC#1
I have searched all over trying to find out where the VSS is in my car and haven't found anything that is helpful. I even looked in that "How To: Find your vehicles VSS" and still didn't find anything for the 2008. My stock head unit had a feature that would increase the volume of the music as the car started to drive faster and I have heard that if it has that feature then the VSS very well could be in the wire harness that plugs into the stock head unit. Is this true? If so, what color is the VSS wire? Thank you for the help!
-Brian
Posted Apr 25, 2009 · 06:02 UTC#2
best bet if no one else knows is to go to the dealer, and ask one of them to bring up the harness diagram, it should say what each wire is. However, I have a question for you, did someone come out with a single din dash kit for the impreza?
Posted May 11, 2009 · 22:16 UTC#3
Pink / Green Wire at the instrument cluster pin #31
Posted Jul 11, 2009 · 01:54 UTC#4
Just wanted to say thanks, this helped me out.
