NOOB on D2
By glogan · Oct 21, 2006in General💬 12 posts👁️ 2,452 views
Posted Oct 21, 2006 · 19:06 UTC#1
Hey guys, just bought a D2 for my 350z and need some help with the install.
I bought the metra wire harness and have everything connected except for the reverse wire and the VSS wire. Has anyone installed the d2 on a 350z and what is the easiest way to connect those wires?
Thanks NOOB question
Posted Oct 21, 2006 · 19:42 UTC#2
Here ya go. THere's a guy here who did what you're doing now so he'll probably be able to help you out with specifics.
Reverse Light orange or lt. green + driver kick, harness to rear
Speed Sense white 8P Unified Meter and A/C Amp, pin 26
Notes: The Unified Meter and A/C Amp is behind the A/C controls in the center console.
Posted Oct 21, 2006 · 21:21 UTC#3
Ok, i think I found the speed sensor but still having trouble with the reverse light. do you know the guy's name on this forum that did the same set-up? Thanks
Posted Oct 21, 2006 · 21:23 UTC#4
Does it matter if the reverse light wire is installed? Does it make a huge difference/error if not installed?
Glenn
Posted Oct 22, 2006 · 00:49 UTC#5
Not really a big difference. As far as his name, I don't remember. He'll probably see this thread soon enough though,
Posted Oct 22, 2006 · 01:58 UTC#6
I don't have reverse hooked up and my D2 does just fine. The only time I go in reverse is when I back out of my driveway, which isn't very far, and it seems like my D2 shows the arrow going backward when I reverse even though I don't have the reverse wire hooked up (guess I have a decent GPS signal).
Posted Oct 22, 2006 · 23:13 UTC#7
Is it really for nav or simply for the reverse camara?
Posted Oct 23, 2006 · 02:26 UTC#8
OK I've got everything hooked up and seems to work fine. How can you run through the whole system to tell if you've got everything in order? which programs should I expect not to work?
I don't have a reverse camera (didn't hook the reverse wire up)
Posted Oct 23, 2006 · 16:45 UTC#9
go to settings, info and look up 3d connection and the other settings button. it should give you basic info... are u getting good signal, is your install ok, etc.
and then just take it for a drive and see how it follows... and take some sharp turns to see if it gets thrown off. make a uturn, reverse, etc...
Posted Oct 26, 2006 · 03:58 UTC#10
ok everything works great... Stupid question though, how do you turn the navigation (screen) off? I figured outhow to turn the AV off but can't with the navi. :D
Posted Dec 22, 2006 · 21:05 UTC#11
So, newb question...but my understanding is that the reverse wire is in the driver's side kick panel and it's light green or orange? I am installing my D2 Monday...just trying to make sure all of my questions are answered before then.
Posted Dec 22, 2006 · 23:48 UTC#12
To turn off nav screen press and hold P.ADJ/B.LIGHT Button.
