Adding photos?
By 06STImatt · Apr 25, 2009in General💬 4 posts👁️ 1,111 views
Posted Apr 25, 2009 · 22:28 UTC#1
Just installed my F900BT. Is there a way to add a personal photo to my background? All I want is a pic of my car on the background but can't seem to figure out how to put in the the radio. Is it possible? I've tried skimming through the user manual but its like 200 pages. Any help would be appreciated. Thanks.
Posted Apr 28, 2009 · 00:53 UTC#2
Check out the Hacks/Mods section of these forums, there are quite a few threads on this. You'll need to get into the testmode to install a user splash screen.
Posted Apr 28, 2009 · 03:57 UTC#3
no you won't.. get a usb/thumb drive make a folder on it called pictures... the max specs of the picture is 800w x 480h... load the pic on to the thumbdrive go into the audio/video setup.. and hit splashscreen hit import from usb.. and grab your pic.. you will only need to do it once.. now then that will be your load up picture.. maybe one of the hackers has found a way to add a permanent background..
Posted May 03, 2009 · 00:03 UTC#4
Thanks for the help.
