I've made a mess when adding my own POI category to the POI list in the Avic unit. Is there any way I can remove it again?
You can remove the Category you created by clicking the Edit button next to it and then click Remove at the bottom.
I figured it out. The specific touch area or button was not correctly translated. In Dutch its says (in contratranslation) 'including subgroups', which should be 'remove'. Your reply helped me though, because I changed the setting to English and then the 'Remove' button showed up.
Thanks,
Jan
