..Between these commands:
"visiblemodel=!navigation.distance_to_manuver.valid"
and....
"visiblemodel="gps.valid"
Thanx,
Bud
and....
Thanx,
Bud
..Between these commands:"visiblemodel=!navigation.distance_to_manuver.valid"
and....
Thanx,
Bud
Depends on context, but basically the former will be visible if you do NOT have a valid distance to next maneuver (basically, not navigating) and the later one will be visible if you have a GPS lock...
Okay...that makes sense.
I was just modding my navmap file and was making the buttons fade out (from alpha32 to alpha20) after I got the code strings figured out and a for instance, lets take the "POI select button" I currently have. In the code I am copying from, the string reads:
And the code I am modifying reads:
...and was just going to replace the "BUTTON xxx" with "BUTTON btnNMB_poi_onmap"...as I have added all of the necessary strings in the common/navmap files to bring these up:
And both iterations seemed to behave the same.
That is what I was questioning. I know that the "!" is the modifier in this case makes the string active when navigating so both are the same in that aspect. One ends in "USE_SEPARATED_SAFETY_MODE=0>" and the other is without.
So, then either one will work?
Thanx,
Bud
That is what I was questioning. I know that the "!" is the modifier in this case makes the string active when navigating so both are the same in that aspect. One ends in "USE_SEPARATED_SAFETY_MODE=0>" and the other is without.So, then either one will work?
Thanx,
Bud
Actually ! means NOT, so it would be visible when not navigating (well, sorta... I suppose there could be a situation when you are navigating, but there's no valid distance yet, i.e. you are pulling out from a parking lot).
