trying to change clock
By zchrisz · Apr 28, 2009in Hacks/Mods💬 8 posts👁️ 1,316 views
Posted Apr 28, 2009 · 01:58 UTC#1
i'm trying to take some code from maverick for the clock, i put it in my stock data.zip but the unit constantly reboots, it's fine when i install the stock data.zip file, is there anything else i need to change before modifying the data.zip file?
Posted Apr 28, 2009 · 02:04 UTC#2
could you clarify this, i put it in my stock data.zip but the unit constantly reboots, it's fine when i install the stock data.zip file
andcould you post the code your trying to copy?
Posted Apr 28, 2009 · 03:25 UTC#3
i added this to the original data.zip file in the navigatemap_800_480.ui file
;time
;added clock adjustment
Posted Apr 28, 2009 · 03:40 UTC#4
You can't just drop random code into a ui. Did you comment out your original clock? Otherwise you'll have 2 clocks. Do you have a "ui_housenumbers" in your navmap8x4.ui?
You'd be better off to just change the font size of your original clock if that is all you are trying to accomplish. Do not unzip the data.zip. Download 7zip and use it to open, not extract the data.zip. Navigate to the navmap8x4.ui. Right click it and hit "edit." Make your changes and close notepad. Click save when asked and then hit update when asked.
Posted Apr 28, 2009 · 10:53 UTC#5
thanks, that my be my problem with ui housenumbers, i did rem out the clock, i'll give it another shot
Posted Apr 28, 2009 · 13:53 UTC#6
ok, i took out ui_housenumbers, same reboot issue, i noticed that in the line of code template=xtxt the code i put in is template=xtxt2 maybe that's an issue.
Posted Apr 28, 2009 · 23:42 UTC#7
found it, i edited the file with 7zip instead of winzip and it worked.
Posted May 01, 2009 · 16:27 UTC#8
CMH, is there a way to change the color of the clock? I cannot see the bright green at all times. I remember you posting a color pallette website - will that work if I open up the data.zip file, change the color, and paste over the stock data.zip? If so, what was that website? Many thanks.
