04 Nissan Titan / AVIC Z1 Install
By troutspinner · Oct 22, 2006in General💬 5 posts👁️ 1,387 views
Posted Oct 22, 2006 · 02:19 UTC#1
Been poking around here for a few weeks and finally pulled the plug on buying a Z1 so I thought I would share a pic of the install. Nothing special but pretty clean looking. I also installed a PACSWIPS along with the unit so if anyone with a similar vehicle has any questions I am sure I can help.
Anyways, here's a couple of pics.
This is just a general pic of how it fit
Library Screen, love my country :)
troutspinner
Posted Oct 22, 2006 · 03:43 UTC#2
Love how that thing fits. By the way great cd.
Posted Oct 22, 2006 · 13:22 UTC#3
Sweet. I'm going to take my original bezel fiberglass the opening and then recut it. I'm going to do my own carbon fiber dash cover.
BTW I have to try the PAC Audio programing again. I have to start by regrounding the system. Then check for connections. I made new connections for the resistors so I'll re do that just in case I did some thing wrong with them.
Again Nice install.
Do you belong to the Clubtitan.com forum?
Posted Oct 22, 2006 · 14:43 UTC#4
djoker,
If you do not have the nav system in your Armada just buy the XE bezel faceplate rather than cutting and fiberglass. The work is already done for you and if you ever want to return the unit back to stock you'll have the parts still around.
I got it at courtesy nissan, a link to the Titan Bezel is here
http://www.courtesyparts.com/Merchant2/ ... 8260-A60CC
and a link to the Armada Bezel is here http://www.courtesyparts.com/Merchant2/ ... 260-TA60CC
The difference between the two would be if you have to the two knobs on the right side.
Scosche (sp?) also sells the bezel for cheaper but it relocates the hazard switch. Personally, I prefer OEM but that's me.
I am not a member there but I will check it out. I am a member of titantalk though.
troutspinner
Posted Oct 22, 2006 · 15:59 UTC#5
Thanks I'll look into that. Well I did the change around and I nominate myself for the DAISY award (Dumb A$$ InStaller of the Year) I went back and looked at the harness I connected and realized that there were only 12 pins. So I looked thru and saw a harness tucked away at the bottom and sure enough there it was. Attached reconnected and programed. I swear the program part was so Dang easy. I have a small tiny delay on the Vol. But that's good for me. I programed Vol +/- Mute Source and preset +/-. Thanks for the help.
K
