detected an improper connection
By ritu_o0o · Apr 28, 2009in Problems/Troubleshooting💬 6 posts👁️ 818 views
Posted Apr 28, 2009 · 17:50 UTC#1
Hi Guys,
A guy did Install my 900BT and perform the hardware bypass, i am not sure whether he did it in proper way or not since i am getting a message "System has detected an improper connection to the parking break...." and nothing works if i go more than 10MPH!!
how do i now proceed for bypass!!! I can not play with wires but very good in software :) ... i read somewhere if i do software bypass on top of hardware bypass i will land up breaking up my unit... is it true!!! can any one confirm it!!
steps for bypass plzz
Thanks in advance
Posted Apr 28, 2009 · 18:40 UTC#2
Hi Guys,
Thanks in advance
check the hacks thread
Posted Apr 29, 2009 · 14:00 UTC#3
sounds like the mute wire is in the wrong pin, and plenty of people have both bypasses done
Posted Apr 30, 2009 · 01:33 UTC#4
Does that means, software bypass will be successful!! since i am not good an wiring I am not sure is my parking break grounded so concerned about the success rate of software bypass!!
plz advice!!
Posted Apr 30, 2009 · 14:27 UTC#5
as long as the parking brake wire is grounded the software bypass will work
OR
search for the hardware bypass for the F-series (the D-series is a little different) and look at the pictures and make sure that your mute wire is in the right pin and your parking brake wire is grounded
Posted Apr 30, 2009 · 22:07 UTC#6
Software bypass worked!! :lol::D
Thank you all!!
