I just recently aquired a new I-Touch and tryed to connect it to my F90 unit and it would not recognize it. My 5th genertation i-pod works fine but it does not seem to connect to the I-Touch. Anyone having the same problem?
I_Touch capable
First (sorry this is a personal thing), it is an iPod Touch... not an iTouch.
Second... do you have the latest software version on the iPod? Or at least version 1.1.4? It should tell you in iTunes when it is connected to your computer.
Also, are you on the latest firmware for the AVIC?
yes, i do have the latest updates for each the f90 and ipod touch. I have the 2.0 version on the f90 and I connected the ipod toch to my pc and uploaded some apps with out it saying that I need to update it. Are you able to connect your ipod touch to your f90 unit?
i have an ipod touch first generation w/ the f90bt ver2.0 and it works flawlessly!
Did you go into the audio devices menu and select Input 1 = ipod?
yes, i did that also.
Have you resolved your problem yet?
nope. I guess ill just use my 5th generation ipod for now
My iPod Touch 1st gen is working, not perfectly but it works. Problem I have is that the iPod doesn't always know it's connected to anything (when it works fine there's a msg on screen saying "Accessory Connected"). Sometimes unplugging it and plugging in again solves the problem, however the most successful remedy I've found is to connect it while it's already playing music.
Quite annoying really but, once it's on, it's on (...until I turn the ignition off. Then it's pot luck as to whether I have to go through the same rigmaroll again next time it turns on).
Just FYI, I have the F700BT (Euro), latest firmware and latest iPod firmware, too.
I have the f90bt and a 2nd gen ipod touch. They work perfectly together. I've never had a problem with this.
My current firmware version is 2.2.1 (5H11a)
I use the ipod mainly to play audio books, but also for video/tv shows when i have a passenger or i'm stuck waiting for a train. (they take forever around here!)
Let me know if I can help with setttings.
infochia
Chevyman, The same thing happened to my ipod video and Ipod touch, how I fixed it was updating itunes AND the ipod (Im pretty sure it was the ipod update that did it but I cant tell exact since I did them both at the same time)
so I went to go outside to try my first gen ipod touch and it didn't recognize it. So im like ok this is interesting, so I noticed I had version 1.1.5 on the ipod and noticed there was a 2.1 update for the touch and iphone for 9.99. Now 10 bux is pretty cheap but im not paying one cent to the Apple corp for and update that fixes their mistakes so I downloaded it from HERE -> http://dl.btjunkie.org/torrent/Ipod-2-0 ... ad.torrent
When installing:
-make SURE your off the Internet
-Make sure you have about 1 gig of space on your pc
-When your in Itunes, hold shift and alt and click update, choose file with update and wait about 5-10 mins for the update to complete
Your done.
Alot of the F series "problems" are not related to the F series
EDIT: Iv done this with the first gen and the second gen ipod touch
And wtf is this doing in the hacks mods section? ![]()
