2007 Jeep Wrangler
By WKYRIDER · Apr 29, 2009in Problems/Troubleshooting💬 3 posts👁️ 755 views
Posted Apr 29, 2009 · 04:15 UTC#1
I have purchased a F900BT and a PAC C2R-CHY4. I tried to install everything today. Everything works except the SOUND!!! Any ideas on what went wrong? I do have one wire that is still loose, amp turn on input, and the directions say that it needs to be wired. Only problem is I dont know what to wire it to. Any ideas?
Posted Apr 29, 2009 · 04:21 UTC#2
if you have a factory amplified system or are using an amplifier, the turn on wire must be connected. Basically its just color coding. make sure you connect the blue/white wire from the pioneer unit to the blue/white wire on the harness. If you dont make this connection the factory amp will not turn on and no sound.
Posted Apr 29, 2009 · 05:02 UTC#3
Thanks for the help. That worked even though the wire I connected it to isnt connected to anything else. I wont worry about it though, it works!! Sounds great too.
