http://artwork-igo8.blogspot.com/search/label/poi
I found this website tonight while searching for a new branding file. I really like there schemes and cars!
Yes. You might need to rename a folder in the branding.zip file, though.
This would be a cool theme to have...
http://1.bp.blogspot.com/_xd8LIIS3Nv8/SM9xNoex-YI/AAAAAAAACkA/tJiHQUeP8os/s1600-h/1331_6.jpg
Most of the schemes need some changes made to the color.ini & color3d.ini files.
Towards the end of the files there are a bunch of lines that look like this: flags="ui_igo8/common/small_flags.spr"
You need to do 2 things:
1 change all instances of ui_igo8 to ui_pioneer so it looks like this: flags="ui_pioneer/common/small_flags.spr"
2 make sure the files being referenced ( in this example the file is small_flags.spr ) are in the correct folders in your data.zip (in this example you would look in the ui_pioneer/common/ directory for small_flags.spr)
If the files aren't in the right places, when you activate the scheme you'll probably start rebooting over and over, so make sure you have all files in the correct folders before using the scheme.
Hope this helps,
infochia
