I know that there would have to be a way to get the 700 to read a divx or xvid file. has anyone found out how to do this? ![]()
Posted May 02, 2009 · 04:41 UTC#1
You can play videos on f700 through using the SD card.
I can play divx on both sd and usb. xvid will play but the video will be very choppy. I always have to encode my xvid to divx to play properly. Also, I found that the frame rate should be about 700. I found that the video gets choppy past 800. I also usually select at least 640 for resolution so that I can get full screen.
how about the f 90. i cant get it to work off of a disc
I can play DivX on F700bt from SD card (16GB) , but the ff and rew doesn't work.. Does it work for you guys?
