Finally I got it to work now, there was fault in my point of view, speedcams are not visible in map mode only in navigation mode. There was my fault.
For others I add to sys.txt to bebug section speedcam_enabled=1
Then I change DATA.ZIP\ui_pioneer\common\ui\ PLACE.UI
this code script sc_StartPlaceMenuPlan
runif vBeta "0" 'btnPMP_SaveAsSpeedcam.hide,btnPMP_EditCam.hide'
runif vBeta "5" 'btnPMP_SaveAsSpeedcam.hide,btnPMP_EditCam.hide'
with
;********************xucheng add *****************
; BM - always show spewedcamera controls
; So just remove original HIDE ;run 'btnPMP_SaveAsSpeedcam.show,btnPMP_EditCam.show'
This code will hide camera controls if you are running US (vBeta=0 or vBeta=5, different models).
Thanks BorisM and this posts viewtopic.php?f=34&t=23102&p=156513&hilit=speedcam+enable#p156513
