IPOD Won't Play F90BT
By tlsmeds · May 02, 2009in Problems/Troubleshooting💬 5 posts👁️ 996 views
Posted May 02, 2009 · 14:13 UTC#1
I just recently installed a F90BT in my 04 F250. I have also done a search and read the FAQ's trying to resolve my problem to no avail. I have plugged my iPod cord into the USB cable from the F90BT and also switched AV1 to IPod. When I plug the iPod in, it shows the album artwork and acts like the song is playing from the time that is counting down on the display, but no music comes from the speakers. Help.....
Posted May 02, 2009 · 15:21 UTC#2
#1 with a bullet,
Did you also hook up the 3 RCA R/W/Y cables to the ipod as described in the installation guide?
USB gives you *ONLY* ipod control,
RCA is for ipod Audio and Video input
Posted May 02, 2009 · 18:01 UTC#3
I did not hook those up. I even went back through the instructions this morning to see if I missed anything. Guess it is time for an eye exam. I appreciate your help!
Posted May 06, 2009 · 22:23 UTC#4
yeah man chances are you missed the RCA's for the cable by accident because if its reading it then it should be playing through your stereo
Posted May 07, 2009 · 02:51 UTC#5
I've got my yellow-red-white cables connected to the iPod (along with USB) and I did the AV1 setting initially. The iPod worked fine. After disconnecting my battery, the AV1 setting was lost and after connecting my car battery again and booting the unit I went crazy when I couldn't hear the iPod until I finally noticed I needed to do the AV1 setting again. I was going crazy until I figured that out. So, if you disconnect the battery, just be sure to set the AV1 setting again if the AV1 setting gets lost. Of course, make sure the yellow-red-white are connected too.
