VSS wire on 2005 Pontiac G6
By asianman35 · Oct 23, 2006in Vehicle Specific Wiring💬 6 posts👁️ 2,415 views
Posted Oct 23, 2006 · 02:10 UTC#1
any ideas? im thinking it should be on the factory harness because the stock radio would get louder as you go faster but i dont know which wire it is!
Posted Oct 23, 2006 · 15:20 UTC#2
Speed Sense brown (3.5L only) PCM, blue plug, pin 22
That's only if you have the 3.5L, PCM is in front of the battery, you MIGHT have a brown wire on your factory radio harness which will be the speed sense but I would put a fuse on it to be sure.
Posted Oct 24, 2006 · 13:02 UTC#3
The power interface module is behind the driver's kick panel, find a brown wire there.
Posted Nov 11, 2006 · 16:19 UTC#4
is there a chance you can post pictures of this wire, i have a 06 GT g6, and i've been looking for this wire, along with the illumination wire. no one seems to haave found it.
Any help would be appreciated.
Aaron
Posted Nov 11, 2006 · 16:37 UTC#5
No photos, sorry. But the power interface module is behind the driver's kick panel, VSS is brown. Illumination is activated through the LAN serial data line running throughout the vehicle, along with accessory.
Posted Nov 12, 2006 · 02:23 UTC#6
In normal people terms, that means you'll have to run a wire from the bcm to the radio opening. Here's where you can pick up the parking light feed.
Parking Lights+ brown + BCM, C3, pin A7
Notes: The BCM (Body Control Module) is part of the fuse/relay box on the front passenger side of the center console. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug.
merry xmas
