F90BT with PAC C2R-FRD1
By StadEMS3 · May 03, 2009in Vehicle Specific Wiring💬 3 posts👁️ 1,934 views
Posted May 03, 2009 · 22:34 UTC#1
This site is increadable! I cannot believe the things that you guys have done with these units.
Well, as you can tell I'm another newb with two questions that i couldn't find on here. So, I'll ask the experts.
I'm using the PAC C2R-FRD1 with my F90BT in my 2007 Explorer Sport Trac. I completed the hard bypass for mute/prarking brake and everything is soldered and shrink tubed. Looks nice if I must say so. Anyway-
1. Does the PAC blue/white amp wire get connected to the F90BT system remote control (amp) wire? I am not using exteral amps.
2. As I said, I did the hard bypass mod and realized the PAC CAN-bus has a red/white parking brake wire too. Does this wire get grounded along with the yellow/black mute wire and light green parking brake wire?
Thanx!
Posted May 04, 2009 · 13:52 UTC#2
Anyone, please?
Posted May 04, 2009 · 14:36 UTC#3
1. If the PAC has a blue/white wire on it, CONNECT THEM. If not, there's no need unless you run aftermarket amps.
2. I'm not 100% familiar with the piece itself, but don't bother with the PAC pb wire. If it's what I think it is, that wire is only meant to give you the vehicle's parking brake to connect to the radio's (non bypass method) via CAN-Bus, and if you ground that your brake indicator will always be on. Cut it, tape it, forget about it.
