F700BT Backup Files EW
By Nacho007 · May 04, 2009in Problems/Troubleshooting💬 7 posts👁️ 2,421 views
Posted May 04, 2009 · 22:13 UTC#1
Hi,
Before I start to make some I made a backup of my flash disk. Unfortunately after apply some mods y lose the bluetooth. So I decide to erase all the files on the flash disk and copy my back up. But something must be wrong with my backup because now I only have the radio working. In the main menu I have a massage that say that the system is starting. I can access to the test mode an the Uboot but I can update the system with the SD an the LPUE080 folder.
If someone could share have a full backup of the European F700bt
If someone could share their backup of the European F700bt I would be really appreciated.
Posted May 06, 2009 · 19:19 UTC#2
Today I delete all the files of the "my flash disk.", including the hidden files of the root directory. Later on I enter in the test mode (pressing eject-menu-map) and reinstall the wince, and finally re-copy my back up. All this doesn't work :( the unit reboot every couple of minutes and only the radio is working. I don't know what files are corrupt in my back up.
Maybe the problem :? is the hidden files of the root directory, if some one could share this files I'll really appreciate.
Posted May 12, 2009 · 08:03 UTC#3
I've searched on the forum for the back up and I've only found the 90BT but the American one. Could someone please share his back up of the European F700BT (without the maps to reduce the size).
Posted May 12, 2009 · 08:33 UTC#4
I've just done a very quick search, I gota go to work now, but try here:
viewtopic.php?t=21618
Posted May 12, 2009 · 10:40 UTC#5
Thanks, I've try but already and didn't fix the rebooting. Maybe is because that backup is of the American version.
http://www.avic411.com/forum/viewtopic.php?t=21618
Posted May 12, 2009 · 19:01 UTC#6
Sorry, I only had a little time. Have you sorted it yet?
Posted May 12, 2009 · 19:56 UTC#7
Yes, I download the backup of the F90BT and transfer to the unit, but it doesn't work. I Change some files, mine is European unit and the backup is American, and it reboot every couple of minutes. I was trying to guessing what files are corrupt in my backup but no way. I've tried too to erase the for gps*.bin, unfortunately not work. Even I have tried to complete the LPUE080 the maps, license, voices, and all the missing things, but I get an error of out of memory.
