How To Turn On Speedcams in GTIMatt's Mod???
By GeezMo76 · May 05, 2009in Hacks/Mods💬 5 posts👁️ 1,275 views
Posted May 05, 2009 · 13:25 UTC#1
I have a good text file loaded in the Speedcam folder. I get no icons, notifications, or warning boxes displaying speedcams on the map. Any ideas?
Posted May 05, 2009 · 14:51 UTC#2
do you have the speedcam_enabled=1 on the debug section of your sys text?
Posted May 06, 2009 · 05:44 UTC#3
You probably need to go to "Navigation... Settings... Warnings..." and enable the speedcams.
You also need to install the speedcam data files...
And the first time you do this, it will take it a good 20 minutes to process the speedcams... so don't freak if the thing is not responsive... Just let it do its thing
Posted May 06, 2009 · 12:59 UTC#4
Updating my SYS.TXT file with speedcam_enabled=1 did the trick.
Posted May 06, 2009 · 13:53 UTC#5
next time read first before you do any mod
