iGO Skin Editor
By BorisM · May 05, 2009in Hacks/Mods💬 23 posts👁️ 16,932 views
Posted May 05, 2009 · 16:37 UTC#1
Somebody had started an editor that can, at least to some degree, read/edit iGO skins...
http://www.andreavb.com/igo8/
Posted May 05, 2009 · 17:33 UTC#2
i have to give this a try
Posted May 05, 2009 · 17:45 UTC#3
It's not perfect, but better than nothing...
Posted May 05, 2009 · 18:18 UTC#4
tried it, i guess all the bmps have to be decompressed for it to properly show up on the editor, also having an error when diplaying the navigate_800_480.ui regarding the time and date, other that looks good
Posted May 06, 2009 · 19:21 UTC#5
Version 1.0.3 hs been posted by author. Seems to be much better at displaying AVIC ui files...
Posted May 07, 2009 · 00:06 UTC#6
the program gives me an error whenever i try opening navigatemap_800_480.ui, i think it has something to do with the time display, was able to open other ui's though, still haven't fixed the decrompressing of the bmp's all in all this would be a good software once the bugs are fixed
Posted May 07, 2009 · 15:47 UTC#7
Interesting. I have ran it on my navigatemap and it did not complain...
Since it only shows one layer at a time, you probably chop out a layer you want to work on and load it separately.
I just ran iPAQ Image Explorer and did batch conversion of all images in Pioneer skin, so now it loads everything...
Posted May 07, 2009 · 17:39 UTC#8
i also did that and still i'm having runtime errors
Posted May 07, 2009 · 18:02 UTC#9
I had it crash on one of the files, but not navigatemap... Oh well, it's a free tool someone's doing in his free time...
Posted May 07, 2009 · 19:14 UTC#10
i agree
Posted May 16, 2009 · 16:07 UTC#11
Hi people, I'm happy to see that someone is using my software. at least someone is trying... :D
ok, I have released new version 1.0.5 and I hope that you find it more stable and powerful than others...
it can decompress BMPs, and render almost all layer elements correctly...you can edit and then save your skin files...
Now I'm working on simulating the skin as in your PDA, you can click buttons to move from a page to another, a complete skin can be loaded at a time. but this will be made in next release maybe it'll take a week or two...
if you want to download the next version visit
and let me have your feedback, it is precious for me
Posted May 16, 2009 · 18:19 UTC#12
thank you for taking the time on making this software
Posted May 17, 2009 · 02:38 UTC#13
Thanks! I'll make sure to try the new one.
It is great that sdomebody is making an iGO skin interpreter. An option to render all visible layers at once would be great...
Posted Sep 09, 2009 · 22:19 UTC#14
just wanted to bring this topic up, another usefull tool for editing, new version is out and now supports skins and simulation
Posted Sep 10, 2009 · 18:40 UTC#15
Hey people, after installiing this software and Decompressing the DATA.zip file into its folder, I could access the Navigation_800_480.ui.
But whenever I try to edit anything, i'm having runtime errors and the program crashes.
What am I doing wrong?!
Posted Sep 11, 2009 · 06:30 UTC#16
did you download the VB6 runtime dLL's? or jsut the exe? you may also need .Net framework.
Posted Sep 13, 2009 · 18:55 UTC#17
Newby! Um how do you use this? I downloaded and installed it. Now how do I get a skin to show up in the editor to edit it? :oops:
Posted Sep 13, 2009 · 23:44 UTC#18
Anybody? Gone through every single folder and nothing that can be opened in the editor in any of them.
Posted Sep 14, 2009 · 00:24 UTC#19
open the editor, click open skin, locate the your data folder, double click the ui_pioneer folder then you'll see on the right side it would show 800_480 and click that and at the bottom right you'll see the open skin is now enabled, click that and mod away
Posted Sep 14, 2009 · 02:21 UTC#20
Opened the editor, clicked open skin, looked in every folder. No such file exist.
Edit - nm, got it.
Posted Sep 14, 2009 · 02:36 UTC#21
you had it wrong, when you click open skin you have to go to where your data folder is, once your in there open it and double click the ui_pioneer folder and you'll see on the right part it would show 800_480, click that and you'll see that the open skin button on the bottom right is now enabled, click that the it would start up
Posted Sep 14, 2009 · 04:32 UTC#22
Had it right, just had to unzip the data folder first otherwise it wouldnt recognize it. Thanks though.
Dont think its going to work for me anyway. I want to edit the AV portion.
