F900 Won't save the settings
By Mofa-a · May 05, 2009in Problems/Troubleshooting💬 7 posts👁️ 617 views
Posted May 05, 2009 · 17:52 UTC#1
Hello!
Having bit of a problem with my unit. I have to change the settings for the iPod (so that it will play) and all the other audio settings everytime I start up the player. I guess this is supposed to save itself or is there a button I have to use? Would really appreciate some help :)
BTW: has the latest update.
Ruben
Posted May 05, 2009 · 19:04 UTC#2
Hello!
Ruben
Sounds like you do not have permanent power connected to the unit...
Posted May 05, 2009 · 19:36 UTC#3
Yea I have thought about that, but the installment was made by an authorized dealer. But you never know. If not anybody else have any idea i might have to take a trip back to the dealership.
Posted May 05, 2009 · 20:48 UTC#4
You never know, indeed... But this seems to be the most likely cause.
Posted May 05, 2009 · 21:12 UTC#5
Ok. Thanks man. Will check up on it:)
Posted May 06, 2009 · 19:13 UTC#6
Problem solved:) Fore some reason the yellow cable hade been connected with the red cable and vice versa :?:
Posted May 06, 2009 · 19:18 UTC#7
Good, at least it should be working now...
